Using Xenon and ethernet on school internet
I know it is not possible to use a particle wifi device to connect to a network where you have to press “Accept” to join the wifi, so I was wondering if I could get a xenon to connect to the internet at my school if I used the ethernet feather wing to use a wired connection instead of a wireless one.
As long as the wired connection does not require you to “accept” terms in a captive portal, then yes, you can use the Ethernet featherwing.
Okay thanks
