Using the CLI to assign wifi credentials to an Argon
When initializing an Argon with wifi credentials one can enter this from a terminal
particle serial wifi --file credentials.json
where the json file has the following format
  "network": "my_ssid",
  "security": "WPA2_AES",
  "password": "my_password"
What is the format of this file if I wanted to give it multiple networks? Do I just wrap the entire doc in square brackets and then add another network like this?
    "network": "my_ssid2",
    "password": "my_password2"
In order to set multiple credentials you need to call the CLI multiple times, each with a file containing a single credential.
