WIFI Credentials via OTA
Hi there, is there a way to change the WIFI credentials of an Argon using OTA? Thanks…
hola Sebastian, and welcome to the community!
I think you can achieve what you want if you use a cloud function that receives the wifi credentials and sets them with setCredentials() or using the wifi credentials class.
Once you set them, I guess you need to deactivate and reactivate wifi, or reset the device, but I can’t tell since I never had to do this…
Best,
Gustavo.
Thanks @gusgonnet. We will give it a try
