Using Argon as a BLE scanner to get RSSI values of BLE Beacons
Dear Members,
I would like to use the Argon as a BLE scanner to scan the RSSI values of BLE beacons, then send the collected RSSI values using WiFi to a TCP client.
I have a similar project running on RedBearDuo. I can compile the code using the particle IDE for RedBearDuo but the same code doesnot compile for Argon.
My questions are:
Can the Argon be used as a BLE scanner ? If yes are there any libraries that I can use ?
I will use the external antennas for WiFi and BLE. Does it makes a lot of difference to use the external antennas instead of internal antennas ?
Any support/suggestions would be great. Thank you.
The BT APIs are currently not exposed for user code, but that’s a top priority.
Hi @u.ahmad, I currently have two RedBear Duos and trying to use the RSSI values to filter output results. The difficulty I am having is finding a segment of code that changes the RSSI report value into a integer or decimal. In the example logger it’s just pulled back as a (report->rssi,dec) but this doesn’t seem to want to convert for me.
How have you got your’s working currently? Have you found a way to then process the RSSI response?
