Hi Community,
On this website https://www.frequencycheck.com/carriers/claro-uruguay it seems to say Claro uses 2100Hz LTE in Uruguay which the B524 should be able to support. Is this possible?
Hi Community,
Using the B524/T524/ONE524 in South America is not officially supported, and is not recommended for growth and enterprise deployments at scale.
However, in the case of countries and carriers that use European frequencies, such as Claro Uruguay and 2100 MHz, it will generally work. However, without the full selection of carriers and bands you may not be able to connect in as many locations.
The other caveat is Brazil, which has permanent roaming restrictions which may cause your device to be banned from the mobile networks after an unspecified amount of time.
