The copy for the particle debugger mentions that it uses Arm’s DAPLink firmware. This is great!
However, I’m unable to find specifics:
- Which firmware does it use? Arm ships a whole mess of
.binfiles and I don’t know which to use. - What’s the update procedure once the correct firmware is located? Double-tap the power button and drag-and-drop?
Thanks a bunch!
