Particle Debugger Firmware
I’m trying to extend the DAP-Link firmware on the Particle Debugger to support flashing my other devices but i don’t know which HIC to use since the GD32F103CBT6 controller on the debugger doesn’t seem to be supported by the DAP-LINK source code of arm-mbed.
Have you implemented your own support for the GD32F103CBT6?
@Bladeking, none of the Particle devices use a GD32F103CBT6 so I doubt they would provide support for it.
The device in question is the Particle Debugger V1.0 device.
And acording the the schematic in the repo:
https://github.com/particle-iot/debugger/blob/master/eagle/Debugger%20V0.4.pdf
The controller on the Debugger is the GD32F103CBT6.
The Debugger uses the open source DAP Link Firmware:
But the ARMmbed DAP LINK repo doesn’t provide support for the GD32F103CBT6.
That is why I’m asking.
This is a question for @rickkas7 since he seems to be the author of the debugger firmware.
It wasn’t me! However, the Particle Debugger firmware is a fork of the ARMmbed/DAPLink source. The modified version is here:
@rickkas7, thank you.
I will try to building the firmware with your repo.:+1:
Hello rick,
My apologies to hack into this thread, but thought use context of the discussion.
Like you just suggested to @Bladeking, I did checked-out and built the DAPLink, and tried to flash the .bin file’s of all variants of k20dx_bl* and k20dx_if*, but none of them made the device to get back into interface mode, but your firmware, always works perfectly
What am I missing here??
Iam trying to investigate a bug within the CMSIS:
Really appreciate your help
