Hi all, just getting started with an Argon and I get a two rapid blue and one whitish or cyan can’t make out it’s really fast and I’m color blind… But its definitely not continuous blue which is needed to pair the Argon to the app.
The app does scan sticker but fails to pair stating failed to connect to your mesh device please try again and keeps failing
Did the dfu mode setups for argon and got to Step 8 where I can run particle update but can’t do the second command because it goes out of dfu mode and goes back to original issue. As it suggests to bring it back to dfu mode, then it says " I was unable to detect any devices in DFU mode …"
This sounds like a DFU error. Please go through the below checklist. If after which, you are still facing issues, please log a ticket at support.particle.io and we will be more than happy to assist.
Thank you for logging this issue. I hear that your device is having issues with regards to entering DFU Mode.
A writeup on DFU: Status LED and Device Modes - Boron | Tutorials | Particle If you wish to program your device with a custom firmware or update DeviceOS via USB, you’ll need to use this mode. This mode triggers the on-board bootloader that accepts firmware binary files via dfu-util.
If you are still not able to get into DFU mode, please try these alternative methods:
Change USB ports and cables. Some users have reported issues with dfu-util on a USB3 ports (typically the blue ones). Use a USB2 port if the USB3 port doesn’t work. Please check your USB cable that it is not faulty and that it should be a data cable.
