Unclear on Argon GPIO mappings
Couldn’t find this in any of the official documentation other than “can be used as GPIO” but hopefully someone can point me in the right direction:
Argon pins TX, RX, MI, MO, SCK, SCL, SDA are all documented as being available for use as GPIO but none of the pinouts show their mappings/assignments.
From the PCB layout is it safe to assume SCL = D1 and SDA = D0?
And then SCK = A6, MO = A7, MI = A8?
And where do TX & RX fit?
TIA
If you look under Docs/Datasheet/Argon you will find this:
YES
YES
Can be referred to either as pin 9 and 10 or TX and RX as in pinMode(TX, OUTPUT);
Thanks for the quick reply! I am familiar with the graphic you referenced. I think a strong argument could be made that additional detail regarding the GPIO naming conventions could be included in this graphic.
