I have an Argon and I want to attach a sensor and use SPI for communication. I need to figure out the pins I need to connect to on the Argon to get the sensor working.
So as far as I can figure out is the following:
Sensor MOSI - to Argon pin MI
Sensor MISO.- to Argon pin MO
Sensor SCK.- to Argon pin SCK
Sensor SI - not sure about this one
Sensor CS - connect to any digital pin?
power and ground I know.
Is this correct?
