No a biggy since I think the pin outs are correct, but when I print the PDF from this URL:
XENON is printed on the picture. It should say ARGON. Are the Argon and Xenon same pins out?
I know that, but when you print it, it shows XENON. Like I said if the pin outs are the same, we are all good.
Oh, I see what you’re saying now. That’s weird and I’m not sure how that is even possible.
It really is the Xenon diagram when you print, and there is one difference: The Xenon has support for USART2, and the Argon does not.
The pins are otherwise the same, so as long as you note that it’s fine.
I drew the pin outs of the Photon and Argon, here is a pic. I think I got the Argon correct. The MD pin is not listed because I am using an Argon adapter from ncd.io Somehow they dont have that pin on their board.
I have the same problem. When I open the “print” dialog in the browser, it says “Xenon”, but I downloaded the PDF file and opened it locally and it said “Argon!”
