Extend RESET & MODE on Argon, Xenon & BoronLTE
Hello,
I need to extend the RESET & MODE button on the Argon, Xenon & BoronLTE, meaning I need to place the buttons elsewhere on the PCB, I’ve been (although fairly painful process) able to solder out wires from the pads of each REST & MODE buttons and connect those to the external push buttons, is there another way, in terms of pragmatically attaching the REST & MODE button functionally to GPIO’s which are a lot more accessible for soldering / wiring out? :slight_smile:
Thanks for your help!
Have you tried using the pins marked MD & RST?
The datasheets are usually a place to look before swinging the soldering iron :wink:
https://docs.particle.io/datasheets/wi-fi/argon-datasheet/
I let the excitement of soldering get the best of me haha, thanks a bunch, saves me from not drinking coffee so my hands would shake less when soldering those teensy pads, am going start a tab for your beer tally :slight_smile:
