As part of my ongoing multi-zone thermostat project, I implemented a UDP -> local linux server for realtime logging, and thought that people might be interested in what was involved. It was actually fairly straightforward once all was said and done. First step was the UDP broadcast on the Spark, as there are some ongoing issues with UDP that are documented elsewhere on the forum. Anyways, I managed to get it working via the tip of calling stop() after every packet. Relevant spark code that gets called every second:
void udpBroadcast() {
char tempString[128];
int sum = 0;
int temp;
Udp.begin(3141);
Udp.beginPacket(IPAddress(10, 0, 0, 255), 3141);
for (uint8_t z = 0; z < NUM_OF_ZONES; z++) {
// Write the zone data (which is set elsewhere and exposed via the Cloud.variable)
sprintf(tempString, "%d:%s::%s,,", z, zoneString[z], actionPID[z]);
temp = Udp.write(tempString);
if (temp < 1) {
Udp.endPacket();
Udp.stop();
return;
sum += temp;
// Write the current status of the relays, and the boiler Temp
sprintf(tempString, "%i|%i|%i|%f", digitalRead(BOILER_PIN), digitalRead(HOUSE_PUMP_PIN), digitalRead(FLOOR_PUMP_PIN), boilerTemp);
if (temp < 1) {
Udp.endPacket();
Udp.stop();
return;
sum += temp;
sprintf(tempString, "\\\\%i\n", sum); // very basic end of string "checksum." Just the length of the printed characters
Udp.endPacket();
Udp.stop();
My home fileserver is running Ubuntu 14.04, so it was pretty straightforward to [install InfluxDB][1] The only hitch I encountered was that I already had a http server randomnly running on one of the default ports, so some config editing was necessary. I also installed [Grafana][2], which acts as a pretty front end for graphing the datalog. I then wrote a quick python script to monitor the UDP port, parse the string that the spark outputs, and write it to the InfluxDB:
#!/usr/bin/python
import socket, sys, json, urllib2
from influxdb import InfluxDBClient
pp = pprint.PrettyPrinter(indent=4)
UDP_PORT = 3141
sock = socket.socket(socket.AF_INET, # Internet
socket.SOCK_DGRAM) # UDP
sock.bind(("", UDP_PORT))
tempString=""
n=0
while True:
data, addr = sock.recvfrom(1024)
tempString+=data
if "\n"==tempString[-1]:
jsondat=[]
words=tempString.split("\\")
if len(words[0])== int(words[-1]):
#print words[0]
segs=words[0].split(',,')
for x in range(0,len(segs)-1):
status,pid=segs[x].split('::')
_,status=status.split(':')
curTemp,setTemp,percOn=status.split('|')
propAct,intAct,derAct=pid.split(',')
jsondat.append({"name":"Zone" + str(x+1),
"columns":["current_temp","set_temp","percent_on","proportional","integral","derivative"],
"points":[[float(curTemp),float(setTemp),float(percOn),float(propAct),float(intAct),float(derAct)],]})
boilerOn,houseOn,floorOn,boilerTemp=segs[-1].split('|')
jsondat.append({"name":"RelayStatus",
"columns":["boiler_relay","house_relay","floor_relay","boiler_temp"],
"points":[[int(boilerOn),int(houseOn),int(floorOn),float(boilerTemp)],]})
req=urllib2.Request('http://localhost:8086/db/Thermostat/series?u=DB_USER&p=DB_PASSWORD')
req.add_header('Content-Type', 'application/json')
response=urllib2.urlopen(req,json.dumps(jsondat))
print response
tempString=""
I havenāt yet set it up, but it would probably make sense to have an upstart script or init.d script run this and keep it running at bootup.
After all this, hereās the pretty result! Iām rather happy with it, especially the resolution that it affords compared to the cloud calls.
[1]: http://influxdb.com/docs/v0.7/introduction/installation.html
[2]: http://grafana.org/download/
