Is there an eta on when the UDP library will be available?
I’ve ordered 10 spark cores for a specific project that requires udp comms, so hoping it wont be too long?
Hi @Dermotos - even though it’s not actually documented on the site, I think UDP has already been implemented. Try it and let us know if it works
I have used UDP for NTP and it worked for me!
I have a Spark and an Arduino (Ethernet) sending UDP messages back and forth:
//// SPARK CODE
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 1, 170); // IP of device we're communicating with
unsigned int remotePort = 8888; // local port to listen on
int RunningLED = 3;
int intervalLED = 5;
#define UDP_TX_PACKET_MAX_SIZE 26
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char RequestBuffer[] = "Hello World\0";
char WeatherBuffer[30];
const unsigned int updateInterval = 30000; // Time interval in milliseconds to send requests
long lastConnectionTime = 0;
// An EthernetUDP instance to let us send and receive packets over UDP
UDP Udp;
// start the Ethernet and UDP:
pinMode(RunningLED, OUTPUT);
digitalWrite(RunningLED, HIGH);
pinMode(intervalLED, OUTPUT);
digitalWrite(intervalLED, LOW);
Udp.begin(remotePort);
Serial.println("Spark UDP test started");
lastConnectionTime = millis();
void sendUDPRequest(){
Udp.beginPacket(ip, remotePort);
Udp.write(RequestBuffer);
Udp.endPacket();
if ((millis() - lastConnectionTime) > updateInterval){
Serial.println("Spark Sending Packet");
digitalWrite(intervalLED, HIGH);
sendUDPRequest();
delay(250);
int packetSize = Udp.parsePacket();
if(packetSize){
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i =0; i < 4; i++){
Serial.print(remote[i], DEC);
if (i < 3){
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
Serial.print("Contents: ");
Serial.println(packetBuffer);
delay(10);
//// ARDUINO CODE
int RunningLED = 3;
UDP Udp;
Udp.endPacket();
sendUDPRequest();
delay(250);
if(packetSize){
if (i < 3){
Serial.print(".");
delay(10);
@ClintonKeith Thanks for putting this code up here. The Spark code worked instantly. I think something like this should be in the standard sketches.
Maybe the Spark Core guys would benefit from also picking a standard piece of free software like Puredata and using that as a way to set up a sketch to receive packets, just so people can get to UDP hello world easily?
