I found two libraries however one appears to use the Analog Pins and the other uses digital pins for the CL and DA lines.
Connect SCL to analog 5
Connect SDA to analog 4
BMP085 SCL to D1
BMP085 SDA to D0
I’m trying to find the spot in one of the libraries where I can adjust this so that they use common pins.
Looking at the TSL2561 library it is using the Adafruit_Sensor class and I am likely going to have to completely gut and rewrite the BMP085 library to work in unison with this.
The only I2C pins on the Photon are D0/D1, but A4 & A5 are the SPI signals MISO and MOSI, but where do you see the reference to A4/A5 in the TSL2561 library?
