Hello guys,
I´m trying to use a PT100 breakout from Adafruit with my Photon (Adafruit Board). The library is not in the Web IDE so I used the “+” to include it in the project. I´m always getting this error when I compile…
What should I do ?
Hello guys,
What should I do ?
I added it to the Particle library and you can find it here: https://build.particle.io/libs/Adafruit_MAX31865_library
System firmware needs to be >= 0.6.2
Thank´s alot, now it compiles !
On more question, regarding the SPI. The example is for Arduino where the pins are 10,11,12,13, hardware pins. In my case, I´m trying to use A2, A3, A4, A5. How do I do that here:
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 sensor = Adafruit_MAX31865(2, 5, 4, 3);
// use hardware SPI, just pass in the CS pin
The code:
#include <Adafruit_MAX31865.h>
//Adafruit_MAX31865 sensor = Adafruit_MAX31865(2);
// The value of the Rref resistor. Use 430.0!
#define RREF 430.0
Serial.begin(115200);
Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
sensor.begin(MAX31865_4WIRE); // set to 2WIRE or 4WIRE as necessary
uint16_t rtd = sensor.readRTD();
Serial.print("RTD value: "); Serial.println(rtd);
float ratio = rtd;
ratio /= 32768;
Serial.print("Ratio = "); Serial.println(ratio,8);
Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
Serial.print("Temperature = "); Serial.println(sensor.temperature(100, RREF));
// Check and print any faults
uint8_t fault = sensor.readFault();
if (fault) {
Serial.print("Fault 0x"); Serial.println(fault, HEX);
if (fault & MAX31865_FAULT_HIGHTHRESH) {
Serial.println("RTD High Threshold");
if (fault & MAX31865_FAULT_LOWTHRESH) {
Serial.println("RTD Low Threshold");
if (fault & MAX31865_FAULT_REFINLOW) {
Serial.println("REFIN- > 0.85 x Bias");
if (fault & MAX31865_FAULT_REFINHIGH) {
Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_RTDINLOW) {
Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
if (fault & MAX31865_FAULT_OVUV) {
Serial.println("Under/Over voltage");
sensor.clearFault();
Serial.println();
delay(10000);
For software SPI:
Adafruit_MAX31865 sensor = Adafruit_MAX31865(A2, A5, A4, A3);
You should instead the Hardware SPI initialization:
Adafruit_MAX31865 sensor = Adafruit_MAX31865(A2);
So finally did it work ? The lib works great on arduino but I can’t get correct values using the particle photon (0.6.2)…
I tried both SPI and SPI1 pins…
Just for nit-picking, the preferable syntax would be
Adafruit_MAX31865 sensor(A2);
as this constructs the object in-place while the other syntax first creates a default object Adafruit_MAX31865(), a temporary object Adafruit_MAX31865(A2) and then assigns the latter to the former.
Yes it worked when I use hardware SPI. My code is like this:
#include "application.h"
#define RREF 430.0
SPI.begin();
float ratio = rtd;
ratio /= 32768;
if (fault) {
Serial.println();
delay(10000);
Yay! I don’t know what went wrong but I copy pasted your code and it works
Thank you Ragnar
Hello Guys. I changed the code a little bit today but now I cannot compile the project…
I get the following error when compiling:
"lib/Adafruit_MAX31865_library/src/Adafruit_MAX31865.h:54:23: fatal error: WProgram,h: No such file or directory
#include “WProgram.h”
It´s the same error I was getting before Kenneth installed the library in the WEB IDE…
Standard response: What system version are you targeting? (double check
Stating this initially (along with other standard info) might save you the extra iterations in a thread.
Firmware on Photon: v0.6.2. Adafruit_MAX31865_library: v1.0.0.
I havent changed anything since last time when it worker but I can see that the library name is not the same now (waw without “_library”)…
Still double check, sometimes Web IDE suffers from amnesia
BTW, how come there is a comma in the error message WProgram,h?
You could also try adding this before your other includes
#define ARDUINO (100)
#include <Arduino.h>
