@DonGar, I can’t see why it would not import. Did you make sure to specify the github path correctly - just your github name and the library path (in your case, DonGar/spark-strip)?
It shows “spark-strip” as a library I contributed at 1.1.0.
Click “Contribute Library”, enter “Dongar/spark-strip”
It now lists both spark-strip 1.1.0 (public), and spark-strip (no version).
The unversioned entry has a flag with a pop up
"Unimported. Finish Validation to Use".
I click “Validate”. The UI processes for a second, then.
The unversioned spark-strip entry on the left hand side is replaced with whitespace, but the flag saying “Unimported. Finish Validation to Use” is still there.
DELETE LIBRARY returns me back to the initial state.
I’m getting tempted to rename the library, and create particle-lib just so I can publish it. I have a number of my own projects that need the updated version with bug fixes.
