Help - Updating a shared library - PietteTech_DHT
It’s been a very long time since I have been on this forum, I decided to update to the photon and get my libraries all updated to work with all variants. I’ve updated my github with the new changes but I can’t seem to import it into the shared library I published over 1 year ago. The library is PietteTech_DHT and it has 1700+ users - so I’d like to get the new library deployed. The interfaces are backwards compatible so there should be no impact to the current user base.
There used to be a button for updating your library in the IDE but that seems to have disappeared.
@mtnscott, welcome back! All you need to do is up the version number in the spark.json file and publish the library. The IDE may warn you about an existing library with the same name but load it anyway. Then publish it to make it public. :grinning:
Thanks! @peekay123 I just imported and published the updated library.
