Hello,
I have been working on connecting multiple sensors (Adafruit DHT22, KSeries CO2, Sensirion SPS30) to a Particle Electron but I have been having difficulty getting the sensors to operate correctly and consistently. When I use an Arduino Uno to test, the sensors work perfectly. As such, I am wondering if there is an efficient method to send sensor data initially from an Arduino Uno to an Electron which I can then use for my desired application. Is it as simple as setting pins in the Arduino as outputs and pins on the Electron as inputs and connecting the two?
