Transfer Code [[ Core >> Photon ]] ?
What the library same code ? if Transfer Code Core to run Photon ?
because it my core is broken T T … i want to buy photon
If I'm not totally mistaken the code if you have it running on the Core now should work with little modification since the firmware uses a HAL, you might have to update your pinouts though.
