Tracker SoM Documentation
There is new Tracker SoM, Tracker SoM Evaluation Board, and Tracker One documentation available!
https://docs.particle.io/tutorials/asset-tracking/introduction/#find-out-more
Most of the documentation can be found in the Tutorials, Reference, and Datasheets sections.
Tutorials
In the Asset Tracking section in Tutorials:
Want to add temperature, pressure, and humidity data to your location publishes using the Tracker Evaluation Board? Check out this example of using a BME280 temperature, pressure, and humidity sensor connected by I2C to add data to location publishes.
And other tutorial resources:
Reference
Datasheets
Here you’ll find detailed technical specifications for the:
If you’re building a carrier board you’ll probably want to use the Eagle CAD Tracker SoM footprint in the Hardware Libraries. You can also import this into other CAD programs.
Known Issues and Errata
Hey Rick, for future visitors, could this one be posted as well under https://community.particle.io/c/tracking-system/58?
