An unmodified Tracker One powered itself off overnight due to low battery. When applying power today, the unit does not come on. Please advise on what to try. Thanks!
Apparently doing this brought it back to life. Is this a different issue, or related to the item below?
I have th ONE404M. I’m afraid now I can’t trust the device to power back on once the battery depletes.
Would you be able to open a support ticket?
https://support.particle.io/hc/en-us
I would like that you share the serial number of your device in the ticket to help you to determine if the device could be affected by this issue.
