Tracker One not connecting after initial Setup
Hello, I have a new Tracker One that will not connect to the cloud after completing the initial setup. On the device dashboard, it says the sim is active, but the status is waiting to connect and the last handshake says never connected.
I have tried device restore over usb shown here:
and this is the Serial monitor output after a successful device restore:
Has anybody else run into this issue? Is there something wrong with the sim?
Is there more log below that? It looks like it's not even attempting to connect to cellular.
You may want to try using particle serial monitor to see if there's anything else.
This was from the Serial monitor output. For the most part, it just repeats [app] TRACE: waiting for stable GNSS lock for triggers and [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
but here is something else further down:
0000603965 [ncp.client] WARN: Resetting the modem due to the network registration timeout
0000603965 [ncp.client] TRACE: NCP connection state changed: 0
0000603966 [net.pppncp] TRACE: NCP event 2
0000603967 [net.pppncp] TRACE: State changed event: 0
0000603967 [ncp.client] TRACE: NCP state changed: 0
0000603967 [net.pppncp] TRACE: NCP event 1
0000603968 [mux] INFO: Stopping GSM07.10 muxer
0000603968 [mux] INFO: Gracefully stopping GSM07.10 muxer
0000603969 [mux] INFO: Closing all muxed channels
0000603969 [mux] INFO: Closing mux channel 1
0000603969 [mux] INFO: Muxed channel 2 already closed
0000603970 [mux] INFO: Muxed channel 3 already closed
0000603970 [mux] INFO: Muxed channel 4 already closed
0000603972 [mux] INFO: Sending CLD (multiplexer close down)
0000604593 [app] TRACE: waiting for stable GNSS lock for triggers
0000604872 [mux] INFO: Received response to CLD or timed out, exiting multiplexed mode
0000604922 [mux] INFO: GSM07.10 muxer thread exiting
0000604922 [mux] INFO: GSM07.10 muxer stopped
0000604923 [net.pppncp] TRACE: NCP event 3
0000604923 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_DOWN
0000604924 [system.nm] TRACE: Interface 4 power state changed: 3
0000604924 [ncp.client] TRACE: Powering modem off
0000605440 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000605487 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000605504 [app.gps.ubx] INFO: AOPSTATUS: iTOW:234405000ms, aopCfg:1, aopStatus:0
0000605593 [app] TRACE: waiting for stable GNSS lock for triggers
0000606593 [app] TRACE: waiting for stable GNSS lock for triggers
0000607593 [app] TRACE: waiting for stable GNSS lock for triggers
0000608593 [app] TRACE: waiting for stable GNSS lock for triggers
0000609593 [app] TRACE: waiting for stable GNSS lock for triggers
0000610415 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000610462 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000610593 [app] TRACE: waiting for stable GNSS lock for triggers
0000611593 [app] TRACE: waiting for stable GNSS lock for triggers
0000612593 [app] TRACE: waiting for stable GNSS lock for triggers
0000613593 [app] TRACE: waiting for stable GNSS lock for triggers
0000614593 [app] TRACE: waiting for stable GNSS lock for triggers
0000615457 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000615505 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000615593 [app] TRACE: waiting for stable GNSS lock for triggers
0000616593 [app] TRACE: waiting for stable GNSS lock for triggers
0000617593 [app] TRACE: waiting for stable GNSS lock for triggers
0000618593 [app] TRACE: waiting for stable GNSS lock for triggers
0000619593 [app] TRACE: waiting for stable GNSS lock for triggers
0000620479 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000620563 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000620600 [app] TRACE: waiting for stable GNSS lock for triggers
0000620625 [net.pppncp] TRACE: NCP event 3
0000620625 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_DOWN
0000620625 [system.nm] TRACE: Interface 4 power state changed: 1
0000620626 [ncp.client] TRACE: Modem powered off
0000620726 [ncp.client] TRACE: Powering modem on, ncpId: 0x64
0000620726 [net.pppncp] TRACE: NCP event 3
0000620726 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_POWERING_UP
0000620727 [system.nm] TRACE: Interface 4 power state changed: 4
0000621593 [app] TRACE: waiting for stable GNSS lock for triggers
0000622593 [app] TRACE: waiting for stable GNSS lock for triggers
0000623593 [app] TRACE: waiting for stable GNSS lock for triggers
0000624593 [app] TRACE: waiting for stable GNSS lock for triggers
0000625459 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000625542 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000625594 [app] TRACE: publishing from triggers
0000626594 [app] TRACE: waiting for stable GNSS lock for triggers
0000627594 [app] TRACE: waiting for stable GNSS lock for triggers
0000628594 [app] TRACE: waiting for stable GNSS lock for triggers
0000629594 [app] TRACE: waiting for stable GNSS lock for triggers
0000629940 [net.pppncp] TRACE: NCP event 3
0000629940 [net.pppncp] TRACE: NCP power state changed: IF_POWER_STATE_UP
0000629940 [system.nm] TRACE: Interface 4 power state changed: 2
0000629941 [ncp.client] TRACE: Modem powered on
0000630431 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000630477 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000630594 [app] TRACE: waiting for stable GNSS lock for triggers
0000630944 [ncp.client] TRACE: NCP ready to accept AT commands
0000631594 [app] TRACE: waiting for stable GNSS lock for triggers
0000631962 [mux] INFO: Starting GSM07.10 muxer
0000631963 [mux] INFO: Openning mux channel 0
0000631963 [mux] INFO: GSM07.10 muxer thread started
0000632065 [mux] INFO: Openning mux channel 1
0000632118 [ncp.client] TRACE: NCP state changed: 1
0000632118 [net.pppncp] TRACE: NCP event 1
0000632145 [ncp.client] TRACE: NCP connection state changed: 1
0000632145 [net.pppncp] TRACE: NCP event 2
0000632145 [net.pppncp] TRACE: State changed event: 1
0000632594 [app] TRACE: waiting for stable GNSS lock for triggers
0000633594 [app] TRACE: waiting for stable GNSS lock for triggers
0000634594 [app] TRACE: waiting for stable GNSS lock for triggers
0000635419 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000635466 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
0000635483 [app.gps.ubx] INFO: AOPSTATUS: iTOW:234435000ms, aopCfg:1, aopStatus:0
0000635594 [app] TRACE: waiting for stable GNSS lock for triggers
0000636594 [app] TRACE: waiting for stable GNSS lock for triggers
0000637594 [app] TRACE: waiting for stable GNSS lock for triggers
0000638594 [app] TRACE: waiting for stable GNSS lock for triggers
0000639594 [app] TRACE: waiting for stable GNSS lock for triggers
0000640451 [app.gps.ubx] INFO: UBX_NAV_ORB: 61 sats in almanac
0000640499 [app.gps.ubx] INFO: UBX_NAV_SAT: 25 sats in view
What SKU is your tracker? 404 or 524?
What region are you in?
On the back of the device, it says the model is ONE523M, and I am in North America, West Coast
Unfortunately the ONE523 will only work in Europe/the rest of the world. It's not supported in North America (modem bands)
Ah not sure how I missed that. Thanks!
