Tracker Edge: Location updates vs publish
Just a data usage question: With plain Tracker edge installed a location update is sent at the Console set interval, using one data slot each time. When adding fields to the location data and publishing them through Tracker::instance().location.regLocGenCallback(myLocationGenerationCallback); as per some of the examples given, does this result in the location being sent through twice (once to the location tracker and once through publish, or are these combined into a single data transfer?
It's combined into a single publish, just adding additional fields to the JSON object, so one data operation. There is a size limit of 1024 characters, however, so there's only so much you can add.
Thanks! As the size of the data in the location changes based on the number of fields in the Tower and Wifi, which take up quite a bit of data. is it possible to turn the wifi and tower fields off?
Yes, it is possible but I wrote the location publisher to simply fill up the rest of the 1024 byte packet and stop adding WiFi APs until the end.
Nicely done, I always appreciate efficient use of data!
