I came across this post from way back in August in which @rickkas7 mentions that part of the new file system is used by the Tracker One for queuing location publishes when the tracker is offline. Was this implemented? The only place I can find use of the file system in the tracker firmware code (at least the code I downloaded in Sept.) is for saving config data.
Steve
