Hello,
I am trying to use libraries that are not already incorporated into the Particle IDE, I am forced to use tool chain gcc-arm local build. I tested out the tool chain using my desired code and it does compile, but it does not run as expected.
The problem:
When I just try to flash a simple Hello World, putting the system on manual mode, the Electron still attempts to connect to the cloud (flashes green) leading me to believe that it is not being flashed the correct code. Can anyone advise me if I am doing something wrong when doing the local build? Or why my electron is still trying to connect to the cloud even though it has been put on manual mode?
This is the exact Hello World that I ran:
#include "Application.h"
SYSTEM_MODE(MANUAL);
void setup(){
void loop(){
Serial.println("Hello World!");
delay(5000);
This is exactly how I went about compiling my code:
I have followed all the steps listed in the Particle Docs (running a mac, if that helps) on how to download and use it.
I created a new folder called Hello in /firmware/user/applications and put the code above in a file called application.cpp in this folder.
As described in the http://particle-firmware.readthedocs.io/en/develop/build/, I changed to the main directory and ran make APP=Hello. It appears to compile successfully and I run “particle flash --serial Hello.bin” from the /build/target/main/platform-0-lto/ directory
Nothing is printed out to the screen after running particle serial monitor and the electron flashes green indicating it is trying to connect to the cloud even though I specifically put the system in manual mode.
If you have any advice or can walk me through how you have successfully used the tool chain and flashed the code to your device, your help is much appreciated.
In case it matters, the firmware on the electron is 0.4.8 (from “particle identify”).
Thank you,
Nicole
