Tachyon setup - sahara_run failed
Running this on Fedora
particle tachyon setup
Produces
Command: /tmp/qdl202575-1451502-1l2qrwv.7ejj/qdl --storage ufs --serial 7DB41BFC /tmp/tachyon-init-files202575-1451502-ndap0g.282o9/prog_firehose_ddr.elf /tmp/tachyon-init-files202575-1451502-ndap0g.282o9/read_gpt.xml --skip-reset
sahara_run failed. Continuing to firehose
waiting for programmer...
Entity: line 1: parser error : Start tag expected, '<' not found
[ERROR] failed to parse firehose response
[ERROR] configure request failed
[ERROR] firehose_run failed
I do work with other Qualcomm SoCs, so my environment may be unique.
Running this on a Mac (arm64) worked
