Tachyon not rebooting, just stays in shutdown mode
I just faced a new behavior with my headless installation:
If I initiate a reboot, tachyon just shuts down and is not automatically coming back anymore. That worked perfectly fine in the past. The single-cell battery is connected and seems to be fine:
Present: yes
Battery: battery (Battery)
Model: 7616544_QUECTEL_SG560D_9450MAH_PM250B_AVERAGED_MASTERSLAVE_JAN6TH2025
Technology: Li-ion
Health: Good
Temperature: 23.0°C
Status: Full
Capacity: 100%
Voltage: 4.195 V (now)
4.200 V (max)
As of now, I have no idea what might be causing it and so far I haven’t found anything useful in the journal. No installation etc for a while. If anyone might have a hint, that would be great :slight_smile:
Booting after pressing the button instantly works, just the reboot is not a reboot anymore.
I am not positive, but there is a possibility that you may need to set autoboot to true.
Will give it a try. I only wonder why it worked without issues before. But I will check that!
Ok, many thanks for the hint. Seems that finally solved it. After setting the parameter and processing a power cycle, it is now working again. Not sure why the parameter was set to false or why it worked before, but for now it seems to be fine :slight_smile:
