Is there a list of compatible countries for the T523 based trackers?
I would like to use a tracker in New Zealand but the only model listed with compatibility for the area is the T524 which sadly doesn’t seem to exist. It seems like they both have the same modem, and LTE CAT 1 is usually fine here, is the T523 not listed as compatible due to the MVNO? Something that could be rectified with a third-party sim?
cheers
Taylor
