Hello everybody,
I have some units that are showing some weird behaviour that I cannot wrap my head around.
I have a function that handles updates as follows:
void CloudClass::handleUpdates()
// Connect, if not connected
CloudClass::instance().connect(DeviceConfigurationConstants::CONNECTION_TIMEOUT);
Class::instance().systemCheckin(); // Watchdog
if (System.updatesPending())
System.enableUpdates();
unsigned long start = System.millis();
while ((System.millis() - start) < DeviceConfigurationConstants::CONNECTION_TIMEOUT)
Particle.process();
// Device normally won't reach this point as it will restart automatically to apply the update.
System.reset(Class::RESET_APP_ENUM::OTA_UPDATE_RESET, RESET_NO_WAIT);
It 'simply' checks if there's any updates pending, if so, enables updates. Problem is that the watchdog gets triggered before the if (System.updatesPending()) line, but the watchdog has a timeout of 5-10 minutes and gets a checkin just before the function is called.
So my question is how the updatesPending works and in what cases can it 'freeze' the execution of the program? Or could it simply be a hardware issue somehow? It's just weird that It stops at the part of the program on each startup, because the units will essentially go into a 'forever' hardware watchdog restart loop.
