System.updatesPending() returns true
System.updatesPending() returns true if System.disableUpdates(); has been called and an update has been attempted but the update does not go through because it was disabled.
The system does not later try to re-flash after System.enableUpdates(); has been called.
I’m thinking that System.updatesPending() should return false after a timeout or if the update failed? Below is the code that I’m using to control the use of updates.
Is there a way to force System.updatesPending() to false is a timeout has occurred?
void systemUpdateScreen(){
            if(System.updatesPending()){
              systemUpdateReady = true;
            if(millis() - systemUpdateTimeOut > 60000){ //time out if update doenst complete within this time
              systemUpdating = false;
            if(millis() - systemUpdateMillis > 3000){
              byte tempNextEvent = currEvent + 1;
              if (tempNextEvent > eventCt) {
                tempNextEvent = 0;
              byte updateDelay = 5; //minutes before mode 2 to prevent system update
              int tempNextStartAdjusted = dataArr[tempNextEvent][0] - updateDelay;
              if (tempNextStartAdjusted < 0) {
                tempNextStartAdjusted += 1440;
              String tempNextStartAdj = String(tempNextStartAdjusted);
              //setWhite19Text();
              //pxs.print(85, 10, String(tempNextStartAdj));
              //printMidText(10, tempNextStartAdj);
              if(mode == 3 || mode == 2 || (currTime >= tempNextStartAdjusted && currTime <= (tempNextStartAdjusted + updateDelay + timeToEnd))){
              } else {
                if(systemUpdateReady && !systemUpdating){
                  pxs.setBackground(255,128,0);  //orange
                  pxs.clear();
                  setWhite19Text();
                  pxs.setBackground(255,204,153); // light orange for antialiased
                  printMidText("System Update", 100);
                  printMidText("Started", 125);
                  printMidText("PLEASE DO NOT", 170);
                  printMidText("TURN OFF POWER", 195);
                  systemUpdating = true;
                  systemUpdateTimeOut = millis();
            systemUpdateMillis = millis();
Hmm, why should it?
As long the update wasn’t pulled it’s still pending, or not?
I might understand the call for a System.declineUpdate() tho’.
Yeah a System.declineUpdate(); or System.retryUpdate() call could do the same.
