Issues with FW OTA update
Hi guys,
I am trying to update my firmware using the Particle console.
I upload my new FW on the console, and when my devices wakes up, it calls this API:
void otaHandler()
 if(System.updatesPending());
     // add a flag
     FWupdate=true;
     Log.trace("updates pending");
I verified that indeed upon system wakeup from sleep, the FWupdate flag becomes true. However, I don’t see that my firmware gets update.
As soon as the this flag is set I call the below APIs:
System.enableUpdates()
delay(120000);
System.reset();
Could anybody comment what I might be missing that makes my system fails updating upon system wakeup.
Thank you all in advance.
@Andre, you may want to try to use a non-blocking delay to replace delay(120000) with:
for(uint32_t t = millis(); millis() - t < 120000L; Particle.process());
This will allow the DeviceOS to get serviced during the pause.
Thank you for your comment!
I actually tried what you suggest by adding the for loop for delay but I have not seen any updates taking place:
function()
    Log.trace("This OTA state before updates are enabled");
    System.enableUpdates();
    Log.trace("This OTA state after updates are enabled");
    Log.trace("This OTA state after delay FW-Ver4");
The above code gets executed when a new firmware update is detected, but I don’t see any updates happen at all.
I just noticed my code keep looping for 2 minutes in this function displaying “This OTA state after delay FW-Ver4”.
Do I need to increase the delay? is this happening because there is not a good handshake between the device and the cloud?
