Stuck into DFU mode with my Electron
I tried to flash my Electron with my own program and now I’m stuck into DFU mode.
First I compile my program.
particle compile electron Vacuum-MPXV4115V.ino --saveTo firmware.bin
Compiling code for electron
Including:
pushing file: Vacuum-MPXV4115V.ino
Memory use:
   text	   data	    bss	    dec	    hex	filename
   8180	     16	    452	   8648	   21c8	/spark/compile_service/shared/workspace/10_electron_15_1/firmware/af16ebef5098a8478b35e32e80dd79a5c223e548bc7a215be30c1e619033/af16ebef5098a8478b35e32e80dd79a5c223e548bc7a215be30c1e619033.elf
grabbing binary from: https://api.particle.io/v1/binaries/56d0cd2b792eec5741e2269a
Compile succeeded.
Saved firmware to: /Users/miotang/Documents/firmware.bin
Work well !
Next, put my Electron into DFU mode.
And flash my Electron :
particle flash --usb firmware.bin
Found DFU device 2b04:d00a
checking file  firmware.bin
spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08020000:leave -D firmware.bin
dfu-util 0.8
Deducing device DFU version from functional descriptor length
ID 2b04:d00a
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 8196
Download	[=========================] 100%         8196 bytes
Download done.
File downloaded successfully
Flash success!
…and now my Electron’s stuck into DFU mode, and I can’t do anything with it.
Please help me !
Mario
Does it still stay in DFU mode after you power cycle?
Please be sure to have upgraded to the latest version of the CLI.
The dfu-flash address is wrong, which has caused your system firmware to be overwritten.
This can be fixed by running particle update, and then reflashing the binary.
Thanks @mdma !
It’s work now… but flashing blue/white rapidely… :fearful:
