[SOLVED] Electron suddenly unable to flash via usb, now in confusing state
5 weeks ago I powered up my first electron (after experience with the photon) and all was good. Flashing over cellular, flashing over usb,publishing events, all was good.
Then, this week, flashes over usb were not working. They would send the device into safe mode however simple the program. Flashes over the air still worked. I suspected I was building bad bins somehow but could not figure that out. My method was:
particle compile electron hello_world.ino
particle flash --usb <electron...bin>  # i removed all old bins, triple checked the file, etc...
I really didn’t want to do all my flashing over cellular, so this morning I decided to try other things
particle update
That looked promising – I figured it might be a firmware mismatch or something, and this looked harmless. Got it from the docs.
Now my electron is in a mode I don’t see documented.
  1. flashing cyan (1 sec), rapid flash cyan (2sec), rapid flash red(<1sec), flashing cyan (2sec) repeat…
  2. I can not get it into safe mode. When I try, I release the reset button, I get blinking purple, I release mode button, I get one breath of white, followed by the sequence in #1
  3. I can get it into dfu-mode, and have retried the “particle update” – no change
  4. If i do a reset, it goes right to pattern #1 above
  5. If i remove power, it blinks green for a while, then goes to #1 pattern
  6. I am still able to do all expected activities with a photon, same computer, etc… yes, I’m carful to check that I am compiling for the right target device.
More details:
$ dfu-util -V
dfu-util 0.8
$ particle --version
1.8.16
    $ particle compile electron hello_world.ino
    Compiling code for electron
    Including:
        hello_world.ino
    pushing file: hello_world.ino
    Memory use:
       text	   data	    bss	    dec	    hex	filename
       4972	      8	   1532	   6512	   1970
    grabbing binary from: https://api.particle.io/v1/binaries/5842f32c899efe67032d431a
    Compile succeeded.
    Saved firmware to: /Users/dandixon/spark/interlock/electron_firmware_1480782634530.bin
     $ particle flash --usb ./electron_firmware_1480782634530.bin
        Found DFU device 2b04:d00a
        checking file  ./electron_firmware_1480782634530.bin
        spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08080000:leave -D ./electron_firmware_1480782634530.bin
        dfu-util 0.8
    Deducing device DFU version from functional descriptor length
    ID 2b04:d00a
    Claiming USB DFU Interface...
    dfuIDLE, continuing
    Downloading to address = 0x08080000, size = 4980
    Download	[=========================] 100%         4980 bytes
    Download done.
    File downloaded successfully
    Flash success!
I now also tried the manual firmware update called out here (for mac):
https://docs.particle.io/support/troubleshooting/firmware-upgrades/electron/
This seemed to go well.
Same result. Although, the rapid red part of the pattern now looks more purple/magenta – not sure if that is a change. Also, it did eventually settle out into a steady blink-cyan mode after a few minutes.
$dfu-util -d 2b04:d00a -a 0 -s 0x8020000 -D system-part1-0.5.3-electron.bin
dfu-util 0.8
ID 2b04:d00a
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 122916
Download	[=========================] 100%       122916 bytes
Download done.
$ dfu-util -d 2b04:d00a -a 0 -s 0x8060000:leave -D system-part2-0.5.3-electron.bin
dfu-util 0.8
ID 2b04:d00a
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 122436
Download	[=========================] 100%       122436 bytes
Download done.
I think you have two (maybe three) separate problems.
First, your CLI is way out of date; the current version is 1.18.0.
sudo npm update -g particle-cli
This is important because particle update does not update to the latest firmware. It updates to the current firmware at the time your CLI version was released. So keeping up-to-date with the CLI is important.
You’re going into safe mode (blinking magenta) after flashing when building with the CLI because the particle compile builds against the latest release system firmware by default, currently 0.6.0. Since your Electron is running something older, you go into safe mode. You can change this behavior by doing:
particle compile electron --target 0.4.8 hello_world.ino
The red flash may be a keys issue. Hold down the MODE button until it blinks blue, then do a:
particle identify
Save the device ID; you’ll need it next.
Then put the Electron in DFU mode (blinking yellow) and do:
particle keys doctor YOUR_DEVICE_ID
particle keys server
It’s probably also a good idea to update your Electron to 0.6.0 and get it into a known state while you’re at it. With the Electron in DFU mode (blinking yellow)L
particle update
particle flash --usb tinker
That was it! I was unaware that the firmware update was tied to the CLI version. Good to know.
An update of my CLI, and a “particle update” on the device did the trick. No issue with keys it seems.
Thanks SO MUCH for the help and the detailed reply. I’m running again!!
-dan
Thanks @rickkas7 for the help!
