Flash success but actually not
I have an electron and an app compiled locally and flashed via serial port. The compilation finished successfully, however there is a problem with the flashing. After I issue the following command:
particle flash --serial firmware.bin
I get:
Flash success!
But the app is still functioning as it would with an older version. I did flash an older version into the electron a while ago. but suddenly I can’t flash any new build.
Anyone has this kind of things happened before?
Try the more reliable
particle flash --usb firmware.bin
in DFU Mode.
You can also do
particle binary inspect firmware.bin
to see what kind of binary you’ve got there :wink:
Unfortunately the same, this is what I get from running the inspect:
firmware.bin
CRC is ok (6fb6d674)
Compiled for electron
This is an application module number 1 at version 4
It depends on a system module number 2 at version 21
Any problem with it?
What was the output of particle flash --usb firmware.bin?
What does particle serial inspect give you in Listening Mode?
What does the RGB LED do after flashing?
Can you try to flash another binary (e.g. simple blink)?
I did an ota to push blink, the app did update. and then I did locally flash using:
output:
Found DFU device 2b04:d00a
checking file /home/build/firmware.bin
spawning dfu-util -d 2b04:d00a -a 0 -i 0 -s 0x08080000:leave -D /home/build/firmware.bin
dfu-util 0.8
Opening DFU capable USB device…
ID 2b04:d00a
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
dfuIDLE, continuing
Downloading to address = 0x08080000, size = 5832
Download [=========================] 100% 5832 bytes
Download done.
File downloaded successfully
Flash success!
The app did switch to my app, but it is an older version…
So I think there might be a problem with the build caching. I did run “make clean” and delete all the previous build files. Here is my script:
#!/bin/bash
echo
BUILD_TYPE="build"
FLASH_SERIAL="no"
if [[ ! -z "$1" ]]; then
  BUILD_TYPE=$1
fi
if [[ "$2" == "flash" ]]; then
  FLASH_SERIAL="yes"
fi
echo build type: $BUILD_TYPE
echo
BASE_DIR="$(cd "$(dirname "")"; pwd)"
APP_DIR="$BASE_DIR/src"
OUT_DIR="$BASE_DIR/build"
OUT_FIRMWARE_NAME="firmware"
echo output dir: $OUT_DIR
echo
CURRENT_DIR=$(pwd)
FIRMWARE_DIR=$BASE_DIR/firmware/main
echo change working dir to: $FIRMWARE_DIR
cd $FIRMWARE_DIR
echo
ERROR=0
continue_to() {
  if [[ "$ERROR" == "0" ]]; then
    ($1)
    ERROR=$?
  fi
if [[ "$BUILD_TYPE" == "clean" ]] || [[ "$BUILD_TYPE" == "rebuild" ]]; then
  continue_to "make clean"
  continue_to "rm -rf $OUT_DIR/*"
fi
if [[ "$BUILD_TYPE" == "build" ]] || [[ "$BUILD_TYPE" == "rebuild" ]]; then
  continue_to "make PLATFORM=electron APPDIR=$APP_DIR TARGET_DIR=$OUT_DIR     TARGET_NAME=$OUT_FIRMWARE_NAME"
fi
if [[ "$FLASH_SERIAL" == "yes" ]]; then
  continue_to "particle flash --usb $OUT_DIR/$OUT_FIRMWARE_NAME.bin"
fi
echo change working back to: $CURRENT_DIR
if [[ "$ERROR" != "0" ]]; then
  echo build error
fi
cd $CURRENT_DIR
I ran
./build.sh rebuild flash
Is there any command that I missed to clean up build?
You should use the Particle make files.
make clean
would be the cleanup command
I did… the md5sum of the firmware.bin is always the same no matter how I change my code.
Sorry, I know I sound silly now
Have read through the docu here?
You need to put your app code in a designated directory or reference the path correctly and you need to execute the command from the correct folder too.
I did read it.
It seems that the build.mk doesn’t detect source files outside of the folder. While I can do:
make APPDIR=/path/to/application/source [TARGET_DIR=/path/to/applications/output] [TARGET_FILE=basename]
to target my source files. But the “make clean” doesn’t delete the build/target folder under the firmware root folder probably doesn’t make sense.
After deleting the firware/build/target folder I can see something else now. My code builds but there is a make error. probably I should start another thread.
