Steady magenta after two seconds of breathing cyan
Hi, I have just claimed my spark core, everything goes fine up to the “breathing cyan” but then after about two breathes (two seconds) the led gets steady magenta.
I have tried to reset it many times, tries to delete the memory and redo the claim, tried with two different wifi AP, I get the same result.
I have gone through the previous messages but I have found nothing similar.
Any hint ?
Magenta only occurs when you are attempting to flash firmware OTA. Are you doing so?
Trying flashing a blank firmware and see what happens!
I have the same problem.
I connect to the cloud (cyan breathing) for a few seconds and then turn solid magenta.
I’ve tried factory reset several times.
over the CLI, when I “spark list”, I get “… is online” for a few seconds, and then after maybe 10 seconds, “… is offline”.
I can’t flash via webapp, I get the error “The server has failed to process the request on time. Please try again.”
@fabio,
What firmware are you running in the core?
Can you reset the core and try again? :wink:
I’ve got the same problem, I’ve factory reseted my Core two times and after trying smart config it breaths cyan and then go magenta. Is there a problem with the cloud? I have another Core which is working fine.
Okay, I found a working solution.
I wasn’t able to flash via webapp, and “factory reset” didn’t do anything.
I compiled the “Blink an LED” firmware and flashed it via USB DFU Mode.
from there, it connected to the cloud again and I was able to flash it with my own app again.
Yes, similarly I flashed the cc3000 update and the deep update over USB with the spark-cli and it now works.
Solved by flashing via USB.
Not particularly easy, had to install a few components on my Macbook and troubleshoot a bit but finally it works.
