Following the Particule Documentation to start mobile application from scratch, I installed Cocoa gem, created a Xcode project, created a Pod file (with no extension) located at root folder of my project where my *.xcodeproj is located. From a Terminal prompt pointing to that directory, I call pod install but get the following error:
Minh-MacBook-Pro:ThermoAlert minh$ pwd /Users/minh/documents/AppProjects/ThermoAlert Minh-MacBook-Pro:ThermoAlert minh$ ls Podfile ThermoAlert ThermoAlertTests Pods ThermoAlert.xcodeproj ThermoAlertUITests Minh-MacBook-Pro:ThermoAlert minh$ pod install Analyzing dependencies [!] The dependency SparkSetup is not used in any concrete target. Minh-MacBook-Pro:ThermoAlert minh$
So I followed instruction from Cocoa guide instead.
And modified the content of my file Podfile with:
target ‘ThermoAlert’ do
pod 'SparkSetup’
end
Then, when trying to install the pod again:
Downloading dependencies
Using 1PasswordExtension (1.8.4)
Using AFNetworking (3.1.0)
Using Spark-SDK (0.5.1)
Using SparkSetup (0.6.1)
Generating Pods project
Integrating client project
Sending stats
Pod installation complete! There is 1 dependency from the Podfile and 4 total pods installed.
Hope this could help other newbies, and would be great if the the documentation gets updated or shows link to seen issues.
