Spark Build can't scroll code on iPad
Hi, I use my iPad to access Spark Build. If I open a project that has more lines than can be displayed on the screen, I can’t scroll down to the remaining lines of code. I have tried Safari and Chrome…
I was playing with Samsung Note and Tab (Android) tablets in a shop the other day and found the same problem.
Scrolling works, you just have to grab onto an invisible bar on the right hand side of the screen. Try tapping about 5% from the right side and pulling down.
You are 100% correct! Thanks.
I just tried Build on my iPad with Safari and Chrome. Unfortunately, I don’t seem to be able to use the Cut and Paste option… :frowning:
Any ideas?
I’m having the same problem, I can scroll but only the code loaded on the full screen before the keyboard pops up. ~ 50 liness or so. Any other suggestions?
