AJBarry
September 13, 2018, 12:30am
1
Hi folks,
I’ve been desperately trying to find a supplier (USA ideally) for the surface mount, vertical-facing JST-2 connector used on the Electron.
The Particle Electron BOM lists it as a KAWEEI CW2001-02T1-H01-D but I can’t find a supplier for that brand (or similar) anywhere.
Thanks kindly in advance!
AJBarry
September 13, 2018, 12:48am
2
As luck would have it, I came across this sparkFun product immediately after posting this thread.
Guess I’ll leave it here in case its of use to anyone else.
Adafruit is also a good source: https://www.adafruit.com/product/1769
Even adafruit sources their connectors from 4uconnector.com … but it’s a super-shady website with no SSL and you have to buy thousands at a time. The adafruit connector is $0.75 compared to $0.95 on sparkfun. Good luck.
AJBarry
September 13, 2018, 1:07am
4
Thanks for the response, for what it’s worth that’s the exact connector we purchased before realising we wanted a vertical-style.
I’ve since found this link also:
https://octopart.com/b2b-ph-sm4-tb(lf)(sn)-jst-248898
