No sorry, I have test 50x lol
Try doing this:
dfu-util -d 1d50:607f -a 1 -s 0x00002000 -v -D core_private.der
This command is ok, but spark keys doctor no…
We had some issues with spark keys doctor recently but i’m surprised that spark keys load keys.der didn’t work for you…
hmmmm…
BTW, what are you trying to resolve? I hope it’s fixed? You can email your public_keys file to @Dave (david@spark.io) for a manual update for now along with your core id…
Is possible to send all command ( key load and key send ) with dfu-util ?
I have my spark last 7 days , it never work. I crying the night !! lol
it will be helpful if you tell us the problem you are facing? Like what is the RGB LED status? Is is flashing yellow?
You can run spark keys send via Spark-cli. It’s not a DFU-util thing but a command to send to the server.
I can’t tell from all that you mentioned to determine the problem
I send a mail for @Dave , thx for help. Damage spark doctor is not functional.
Heya, got your email, can you give it a try now?
David
Hey, there it goes! Nice job getting a new key on your core, sorry it wasn’t working perfectly the first time!
David
I fel
spark keys load plop
and
dfu-util -d 1d50:607f -a 1 -s 0x00002000 -v -D plop.der
I have always flashing cyan !
Edit : after five minute is OKKKKKK, big thx !
I added the key right away, and then realized I was still pointed at the staging environment from my dev work yesterday
– so that 5 minute delay was me!
David
Hi @Dave
Good day to you. I tried the suggestion you gave
spark keys new test1
spark keys load test1.der
spark keys send 54ff6f066672524845300167 test1.pub.pem
But I’m still having the same set of problem as the OP.
➜ ~ sudo spark keys load test1.der
Password:
running dfu-util -l
FOUND DFU DEVICE 1d50:607f
running dfu-util -l
running dfu-util -d 1d50:607f -a 1 -s 0x00002000:1024 -U pre_test1.der
running openssl rsa -in pre_test1.der -inform DER -pubout -out pre_test1.pub.pem
Saved!
checking file test1.der
spawning dfu-util -d 1d50:607f -a 1 -i 0 -s 0x00002000 -D test1.der
dfu-util 0.8
ID 1d50:607f
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
Device returned transfer size 1024
DfuSe interface name: "SPI Flash : SST25x"
Downloading to address = 0x00002000, size = 610
Download [=========================] 100% 610 bytes
Download done.
File downloaded successfully
Saved!
Everything was a success but the core still does not connect to the wifi.
after spark setup wifi
It goes from flashing green to red.
oh @Dave, that is because I have 2 different core facing 2 different issues.
1 is an existing core that keeps flashing green to red
another is a new core that keep flashing green.
Sorry for the misunderstanding, if you think I’m spamming.
Bryan
