jacco
1
Since a week or so I can’t use the WebIDE not anymore.
I’m getting and endless spinner in a empty IDE.
The console of Google Chrome (44.0.2403.130 m) is showing me the following errors and warnings:
Is this a back-end problem or should a look for the problem at my side?
Jacco
Moors7
2
If possible, could you try logging out/in again (possibly clearing the cache of your browser)? That often helps.
bko
3
I have often found that the WebIDE works best in incognito mode in Chrome for me.
jacco
4
I can’t log out. The only control that is working is Docs.
@jacco, kill the browser, purge you cache and try again. If it connects automatically, try logging out again then back in.
jacco
6
Incognito mode is working indeed.
Clearing the cache in normal mode also helped.
By the way I had this problem across different devices (Windows and OSx).
Thanks guys.
