Been using my particle for days with no problem and suddenly it wasn’t running my code and I was seeing weird on-board led patterns like blinking red and such. So I am attempting a factory reset but for the reset I’m not seeing the expected lights:
Holding both buttons
Releasing Reset button while still holding Setup button
See blue/red blinking for a couple of seconds
Then seeing blinking yellow forever … after 20 seconds I give up.
What does this mean? Am I missing something in the instructions?
Thanks.
Your device isn’t toast, but there’s most likely an error in your code somewhere. Try holding setup, and pushing reset. Release once it goes into blinking magenta (blue+red). That’s safe mode, which will only run system firmware. That should get you connected to the cloud again, after which you should be able to flash your code wirelessly once more. Give “blink an LED” or Tinker a try, and you should see your device working again
So perhaps this should now be a different thread, but I tracked down the offending code:
attachInterrupt(D2, myfunctionname, CHANGE);
This throws my particle into hard fault mode every time. The function is declared void myfunctionname(void) first as per the documentation, and then is defined later. It has no implementation at this point.
