[SOLVED] How do I select the correct photon on the IDE to flash the code?
Mod Edit (@harrisonhjones): Solution: If you take your mouse cursor and put it slightly to the left of the name of the Photon you want to flash a star will appear. Click the start and it should turn yellow. That device is now your default device to flash to and compile against.
Hello folks,
My apologies if this has been asked before, but I have three photons, I see them listed on the IDE, my question is: how do I select one of them to flash the code? I dont find a way to indicate me that I will flash the code to the correct photon.
By the way, nice little device, I love the OTA capability. Set it and forget it. One of them is stuck deep into the arctic , do you guys/gals think that I want to be up and down pulling the little thing to change the code? No in my dreams :smile:
If you take your mouse cursor and put to slightly to the left of the name of the Photon you want to flash a star will appear. Click the start and it should turn yellow. That device is now your default device to flash to and compile against.
Yes, Sir! That is the indication I was looking for, thank you for quick response.
