When I claimed my Photon, it was flashing orange so I got new keys using the CLI.
I can flash the Photon from the Build IDE no problem.
When I flash from the Dev IDE the LED flashes purple but the Photon does not restart. I waited about 5 mins and then hit the reset button but the old code was still running. I tried multiple times.
I tried in safe mode with the same result.
I flashed the same code to another Photon using the Dev IDE with no problem.
Can anyone help?
What else should I try?
Would the keys issue when I claimed the Photon have anything to do with it?
