I am creating a project and want to use the B and C pins on the Electron. While prototyping I get the following error:
electron_v1.cpp:30:21: error: 'B5' was not declared in this scope
The same error occurs when using C pins.
This is my code:
const int out1Pin = C2; // H-bridge leg 1 (pin 2, 1A)
const int out2Pin = B5; // H-bridge leg 2 (pin 7, 2A)
I can set pin numbers for B and A pins and they turn purple in the IDE, but the C and B pins stay white.
Can someone help me with this problem?
