Very simple Electron app that is (for staters) periodically reporting a 12v battery voltage to Particle cloud and webhooking over to Mail Gun.
I am using the Web build environment.
Next step is to connect up to MyDevices.
I included the cayenne-particle library, so now the app starts out with …
#define CAYENNE_PRINT Serial
#include <cayenne-particle.h>
Subsequent build of the app can’t find cayenne-particle.h
What am I doing wrong?
Cheers
ScruffR
2
If your code looks like that then you are missing a closing >
If you do have that in place you're probably targeting a version 0.5.2 or before. Go for 0.6.4+
Cut past error on the closing >
The Electron reports 0.4.8. Its been sitting for awhile. I’ll update it to latest stable version.
Cheers
I updated the Electron to 0.6.0, that cleared up the compilation error. Thanks
But I’ve since shifted gears to Losant (seems a faster path versus MyDevices, Ubidots). Integration of the Particle trigger was very easy.
RWB
5
Losant is a great choice.
