Sim Card ethersim
When I use the particle sim, it detected the network but it keeps disconnecting and cannot authenticate to the network, but when I disable it obviously I completely stops working. Currently in Australia
Which device are you using? How is it powered?
Getting a log from web device doctor may be helpful.
Currently I’m using a gps tracker I bought online, and I also tested in it my phone
The Tracker One or Monitor One? Which model (there are two of each, for example ONE402 or ONE523)?
I got a cheap random one off Aliexpress, but I don’t understand why it access data, it let it connect but it doesn’t allow data
I'm sorry, I can't figure out what you are doing:
Are you trying to use the Particle EtherSIM 4FF plastic SIM card in a non-Particle cellular device?
If not, which is the Particle device you are using? Boron? Which model?
Yes I’m using a particle sim in a none particle device
Using a Particle SIM in non-Particle device is not recommended. You'll need to set the APN in order to get data transmission to work, but there are several different Particle SIM cards, which have different APNs. And of course how you set the APN will depend on what you've put it into.
Is there any chance I can dm you the SIM card code and you can tell me the apn?, I had it auto populate from the the sim but it doesn’t work
After guessing and checking I found it was
wireless.twilio.com
