I have several devices that go through the following sequence:
Breathing white (other internal processes before connecting)
move to breathing blue (which I believe is cellular/sim related?)
eventually give up, go back to sleep (my code dictates this after 60 seconds of failure)
What they should be doing, and many other devices with the same code/version correctly do:
Breath white
Flash green
strobe cyan
breath cyan (connected, doing their thing)
disconnect and go back to sleep.
What’s possibly different on these devices is that they are ~5 from a batch of 15 that were offline/battery disconnected from around 3/6 or 3/7 and were reconnected yesterday. I’ve let them cycle quite a few times hoping it was just network provisioning, but no such luck in rehabilitating. Code worked (and has been untouched) 3/6-3/7 prior, in most cases for months. Others from same batch fired back up after their disconnect without issue.
clouddebug: press letter corresponding to the command
a - enter APN for 3rd-party SIM card
k - set keep-alive value
c - show carriers at this location
t - run normal tests (occurs automatically after 10 seconds)
or tap the MODE button once to show carriers
starting tests…
turning cellular on…
deviceID=((hidden))
manufacturer=
model=
firmware version=
ordering code=
IMEI=
IMSI=
ICCID=
0000135436 [app] INFO: enabling trace logging
attempting to connect to the cellular network…
0000135436 [system] INFO: Sim not inserted? Detecting…
[ Modem::powerOn ] = = = = = = = = = = = = = =
135.746 AT send 4 “AT\r\n”
137.057 AT send 4 “AT\r\n”
138.368 AT send 4 “AT\r\n”
139.679 AT send 4 “AT\r\n”
140.990 AT send 4 “AT\r\n”
142.303 AT send 4 “AT\r\n”
143.614 AT send 4 “AT\r\n”
144.925 AT send 4 “AT\r\n”
146.236 AT send 4 “AT\r\n”
147.547 AT send 4 “AT\r\n”
[ Modem reset ]
158.858 AT send 4 “AT\r\n”
160.169 AT send 4 “AT\r\n”
161.482 AT send 4 “AT\r\n”
162.793 AT send 4 “AT\r\n”
164.104 AT send 4 “AT\r\n”
165.415 AT send 4 “AT\r\n”
166.726 AT send 4 “AT\r\n”
168.037 AT send 4 “AT\r\n”
169.348 AT send 4 “AT\r\n”
170.659 AT send 4 “AT\r\n”
[ No Reply from Modem ]
171.861 AT send 6 “ATE0\r\n”
0000181863 [system] INFO: Sim not inserted.
