xxxxxx:~ xxxx$ particle setup
_ __ _ _ _
| '_ \ __ _ _ __| |_(_) ___| | ___
| |_) |/ _` | '__| __| |/ __| |/ _ \
| __/| (_| | | | |_| | (__| | __/
|_| \__,_|_| \__|_|\___|_|\___|
https://particle.io
> Setup is easy! Let's get started...
> It appears as though you are already logged in as xxxx@gmail.com
? Would you like to log in with a different account? No
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
> I have detected a Photon connected via USB.
? Would you like to continue with this one? Yes
! The Photon supports secure Wi-Fi setup. We'll try that first.
! PROTIP: Wireless setup of Photons works like a wizard!
! PROTIP: We will automagically change the Wi-Fi network to which your computer is connected.
! PROTIP: You will lose your connection to the internet periodically.
? Found "Photon-xxxx". Would you like to perform setup on this one now? Yes
! PROTIP: You will need to know the password for your Wi-Fi network (if any) to proceed.
! PROTIP: You can press ctrl + C to quit setup at any time.
> Obtained magical secure claim code.
> Hey! We successfully connected to Photon-xxxx
> Now to configure our precious Photon-xxxx
! PROTIP: If you want to skip scanning, or your network is configured as a
! PROTIP: non-broadcast network, please enter manual mode to proceed...
? Would you like to manually enter your Wi-Fi network configuration? Yes
? Please enter the SSID of your Wi-Fi network: xxxx
? Please select the security used by your Wi-Fi network: WPA2
? Please enter your Wi-Fi network password: xxxxxxxx
> Here's what we're going to send to the Photon:
> Wi-Fi Network: xxxx
> Security: WPA2
> Password: xxxxxxxx
? Would you like to continue with the information shown above? Yes
> Obtaining device information...
> Setting up device id xxxxxxxxxxxxxxxxx
> Requesting public key from the device...
> Setting the magical cloud claim code...
What’s the colour of the LED on the photon?
