Is there a way to change the output of Serial Log Handler from the Serial port to an attached TFT screen? So instead of Serial.print() it will be doing tft.print().
Nope, but you can write a log handler that can be used in place of SerialLogHandler
BTW, if you want to use SerialLogHandler
you wouldn’t use Serial.print()
but the dedicated Log.xxx()
functions.
@ScruffR Would you be able to direct me to any examples or should I just go and find the source on github? Thanks
You can have a look at the implementations of this community contributed hanlder
https://docs.particle.io/reference/firmware/photon/#community-log-handlers
Or this by @rickkas7
Brilliant thanks!
